Showing results for tags 'ImperiHome 2.6 Fibaro HC2 s'.
  1. Maybe one of the most awaited version of ImperiHome is now available! Indeed, version 2.6 released a few hours ago is compatible with Fibaro HC2 home automation system! What about the HC Lite? At the time I write this post, the V4 firmware is not yet available on the HC Lite. As soon as it will be the case, and subject the API will be the same, it will work like a charm! http://www.imperihome.com/blog/2015/07/24/imperihome-2-6-fibaro-hc2-support/
