Hi all, I have problems with the script below. Can anyone say what is going wrong? I have debug message added at the bottom. Thanks You. Thanks to MSB for the script
--[[ %% autostart %% properties %% globals ActivityProjector ActivityTV LastSeenHans LastSeenChrista TV Projector Home Night --]]
--kill any extra instances of the same scene if (fibaro:countScenes() > 1) then fibaro:abort() end;
--Loop while true do
--Settings local ExecuteTimer = 60; -- Execute Every N-th second local GlobalVariablesDevice = 174; -- ID of helperdevice for GlobalVars! local AbsenceTime = 10; -- 10 minutes local SunriseTime = 30; -- 30 minutes after sunrise local SunsetTime = 30; -- 30 minutes before sunrise local UserInactivity = 10; -- 10 minutes delay after switchoff
--Setup local variables local CurrentDate = os.date("*t");
--Announce start fibaro:debug(" -|- Start: "..os.date("%Y-%m-%d %H:%M:%S",os.time()))
-- LastSeenHans,Christa fibaro:call(GlobalVariablesDevice, "pressButton", "11"); -- Check if Hans is at Home fibaro:call(GlobalVariablesDevice, "pressButton", "12"); -- Check if Christa is at Home local LastSeenHenrik = fibaro:getGlobalValue("LastSeenHans"); local LastSeenJennie = fibaro:getGlobalValue("LastSeenChrista"); fibaro:debug(" -|- LastSeenHans: "..os.date("%Y-%m-%d %H:%M:%S",LastSeenHans)); fibaro:debug(" -|- LastSeenChrista: "..os.date("%Y-%m-%d %H:%M:%S",LastSeenChrista));
-- Home, anyone ? AbsenceTime = os.time() - (AbsenceTime * 60); fibaro:debug(" -|- AbsenceTime: "..os.date("%Y-%m-%d %H:%M:%S",AbsenceTime)); if tonumber(LastSeenHans) < AbsenceTime and tonumber(LastSeenChrista) < AbsenceTime then fibaro:debug(" -|- Home: Noone is Home!"); if tonumber(fibaro:getGlobalValue("Home")) == 1 then fibaro:setGlobal("Home", 0); end else fibaro:debug(" -|- Home: Someone is at home!"); if tonumber(fibaro:getGlobalValue("Home")) == 0 then fibaro:setGlobal("Home", 1); end end
-- SunriseTime SunriseHour = os.time{year=CurrentDate.year, month=CurrentDate.month, day=CurrentDate.day, hour=string.sub(fibaro:getValue(1, 'sunriseHour'), 1 , 2), min=string.sub(fibaro:getValue(1, 'sunriseHour'), 4)}+SunriseTime*60; fibaro:debug(" -|- SunriseTime: "..os.date("%Y-%m-%d %H:%M:%S",SunriseHour));
-- SunsetTime SunsetHour = os.time{year=CurrentDate.year, month=CurrentDate.month, day=CurrentDate.day, hour=string.sub(fibaro:getValue(1, 'sunsetHour'), 1 , 2), min=string.sub(fibaro:getValue(1, 'sunsetHour'), 4)}-SunsetTime*60; fibaro:debug(" -|- SunsetTime: "..os.date("%Y-%m-%d %H:%M:%S",SunsetHour));
-- Night or day? if (os.time() > SunsetHour or os.time() < SunriseHour) then fibaro:debug(" -|- Night: It's night!"); if tonumber(fibaro:getGlobalValue("Night")) == 0 then fibaro:setGlobal("Night", 1); end else fibaro:debug(" -|- Night: It's day!"); if tonumber(fibaro:getGlobalValue("Night")) == 1 then fibaro:setGlobal("Night", 0); end end
-- TV running? if tonumber(fibaro:getValue(19, "valueSensor")) > 10 then fibaro:debug("-|- TV: TV is ON"); fibaro:setGlobal("ActivityTV", os.time()); if tonumber(fibaro:getGlobalValue("TV")) == 0 then fibaro:setGlobal("TV", 1); end elseif (os.time()-(60*UserInactivity)) > tonumber(fibaro:getGlobalValue("ActivityTV")) then fibaro:debug("-|- TV: TV is OFF"); if tonumber(fibaro:getGlobalValue("TV")) == 1 then fibaro:setGlobal("TV", 0); end else fibaro:debug("-|- TV: TV is Undetermined"); end
-- Projector running? if tonumber(fibaro:getValue(19, "valueSensor")) > 10 then fibaro:debug("-|- Projector: Projector is ON"); fibaro:setGlobal("ActivityProjector", os.time()); if tonumber(fibaro:getGlobalValue("Projector")) == 0 then fibaro:setGlobal("Projector", 1); end elseif (os.time()-(60*UserInactivity)) > tonumber(fibaro:getGlobalValue("ActivityProjector")) then fibaro:debug("-|- Projector: Projector is OFF"); if tonumber(fibaro:getGlobalValue("Projector")) == 1 then fibaro:setGlobal("Projector", 0); end else fibaro:debug("-|- Projector: Projector is Undetermined"); end
--Announce end fibaro:debug(" -|- End: "..os.date("%Y-%m-%d %H:%M:%S",os.time()))
--Sleep XX seconds fibaro:sleep(ExecuteTimer*1000); end
[DEBUG] 18:20:41: -|- Start: 2015-03-21 18:20:41 [DEBUG] 18:20:41: -|- LastSeenHans: 2015-03-21 18:20:41 [DEBUG] 18:20:41: -|- LastSeenChrista: 2015-03-21 18:20:41 [DEBUG] 18:20:41: -|- AbsenceTime: 2015-03-21 18:10:41 [ERROR] 18:20:41: line 46: attempt to compare nil with number
