Showing results for tags 'RGBW-dimmer'.
  1. I have a RGBW dimmer module (working on 12V) to drive a couple of spotlights. The dimming level (from 0 to 100%) with a Halogen spotlamp (50W) is perfect, but with LED spotlight it isn't that great, as i ordered and tested a couple ones from Aliexpress! (LEDspot with COB led build in - dimmable) 1. In your opinion and advice which type - brandname - wattage LEDspot works BEST with the RGBW controller from Fibaro ? 2. Referring to Question number 1, is the dimming level still great with a single or twin LED-spots which works BEST for you?
