Showing results for tags 'Roller Calibration'.
  1. Guest
    Roller Shuter issue
    Dear Fibaro community, until today i had no issue´s with my fibaro Equipment. No i hope that somebody got an idea to help me with this issue: i mount the fibaro roller shutter (i think) correctly with the Roller engine and connect the module with the HC2. After this i started the calibration (in HC2) and the roller moved up down and up. Now i wanted to use the app(or within HC2 the arrows up/down) to open and Close the shutter but beside a click-sound and the Red and green light in the module nothing happend. Also the Manual switch doesn´t work. When i make a calibration run and use the Manual Switch the calibration stops. Do you might have an idea how to solve this issue? Kind regards Mike
