Showing results for tags 'Roller shutter projector scre'.
  1. Hi, I planned to control my projector screen by using the roller shutter module. Unfortunately the wiring looks different than expected... My projector screen has a control box, which provides 3 buttons (up, down, stop) and a receiver for the RC. I thought it should be simple to connect the Roller Shutter module between the control box and the screen motor. The cable from controler box to the screen has 4 wires: - Black - Brown - Blue - Yellow/Green (Ground) Dependent on the situation I can document the following details: off down up off (upper position) (lower position) Black power power power power Brown n/a power n/a power Blue power n/a power power It looks like the motion is controlled by Brown and Blue, but why do I have additonally a Black wire which provides constant power? I also don't have a Neutral wire. I'm confused. Please help. How do I need to connect the Roller Shutter? Thanks, Klaus
