Showing results for tags 'Variables Global Pre-defined'.
  1. Hi. Quick general question for the forum. If I define a set of pre-defined global variables, such as the following: Variable: AlarmMode Values: Stay, Away, Sleep What is the behavior of the system upon startup in terms of which VALUE will be default at start? Can this be changed?
