Showing results for tags 'adjust time'.
  1. I was looking for a way to change the sunset time. All solutions I found did manipulate the current time and compare that with the sunset time. That's not the way I wanted it so I wrote a small function to subtract or add minutes to the sunrise or sunset given time. -- time is a string format: hh:mm -- offset is in minutes -- return string format: hh:mm function ChangeTimeWithOffsetInMinutes(time, offset) local currentDate = os.date("*t"); local format = "(%d+):(%d+)"; hour,min = time:match(format); local newTime = os.time({day=currentDate.day,month=currentDate.month,ye
