Showing results for tags 'aeotec nano dimmer'.
  1. It is becoming increasingly irritating that Fibaro has failed to provide a template for full support of the Aeotec Nano Switches and Dimmers. The Home Center 2 does not synchronise properly with the momentary switches so the lights can be off when it is still showing as on. The energy consumption continues to increase based on the previous reading that stays "stuck" on on. If I go to the Read Configuration option on the web interface, it will read the configuration of the device and reset all the readings. This is the only way I know how to get it to synchronise with the device apart from pressing the off button on the App or the web interface. But even then I need to do a read configuration to get the energy monitoring status correct. So, it seems to me this is a top selling product and it is a direct competitor to Fibaro equivalents so Fibaro is dragging its feet in providing proper universal support for z-wave. This is totally contrary to the way z-wave alliance partners should behave.
