Showing results for tags 'air conditioner. metering'.
  1. Hi, I'm mounting 3 new air conditioners inverter from BEKO... each with one outdoor unit and one indoor unit (mono-split). The advantage of using these conditioners is that have the auto restart when power is removed. I can control the power on/off with a simple relays connected on main power of the air conditioner. I Know that I can control they with the z-wave to IR but I need only to turn on/off the air conditioner and check comsuptions. I thought to use a single relays switch with metering (Aeon labs micro smart energy) and connect to main power (before air conditioner connection) It's a good idea? Any suggestion to control power consumption and turn on/off thee air conditioner? Thank you
