Showing results for tags 'alarm state'.
  1. Hi all, I never used magic scenes before, only block scenes. But I'd like to split the notification part when alarm goes on or off, leaving in block scenes the duty part. The problem is that, as the title says, the magic scenes do not start when the alarm changes its state. Running them manually, the push notification is send. I tried other magic scenes: only those based on alarm state are not executed. Reading the forum it seems the problem is shared with HC2 firmware
