Showing results for tags 'api device id'.
  1. Hi I have for a while used my own functions to do what is missing in the API. Now... I have for example code similar to this in both buttons and main section of VDs. It would be nice if someone could tell me if there has been added something built-in like "getIDFromName" so I can remove such functions from my code and instead rely on Fibaro built in functions. Asking as I have a few VDs with big code bases. And I have hit the Fibaro max code base limit several times. So... To be able to extend the code, I have to make it smaller first.... function getidfromname(z) HOST = Net.FHttp("127.0.0.1",11111); response ,status, err = HOST:GET("/api/virtualDevices"); local jsonTable = json.decode(response); for virtualIndex, virtualData in pairs(jsonTable) do if (virtualData.type=="virtual_device") then if virtualData.name == z then return virtualData.id end end end return nil; end ID = virtualdeviceexist('vd_name_to_get_ID_from') Tnx Peo
