Showing results for tags 'api put'.
  1. Good morning, even though I read the documentation and everything works with GET/POST/DELETE, I can't understand what I have to do to modify a room that exists (id=279); I always receive return code 400: [DEBUG] 09:01:40: response.status 400 [DEBUG] 09:01:40: failed [DEBUG] 09:01:40: response.data {"type": "ERROR", "reason": "id", "message": "no id"} [DEBUG] 09:01:40: type ERROR [DEBUG] 09:01:40: message no id [DEBUG] 09:01:40: reason id Here are the instructions: --[[ --%% autostart %% properties %% globals --]] print('crearoom') created = false stanzaID = 0 stanzaid=279; nameRoom="newstanza"; sectionIDRoom=219; print('chiamataPUT') date = os.date(); requestBody = {body = {name = nameRoom, sectionID=sectionIDRoom}} httpClient = net.HTTPClient() httpClient:request("http://127.0.0.1/api/rooms?id="..stanzaid, { options = { data = json.encode(requestBody), method = "PUT", headers = { ["Content-Type"] = "application/json", ["Accept"] = "application/json", ["Authorization"] = "Basic XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX", } }, success = function(response) print('response.status '..response.status) if response.status ~= 200 and response.status ~= 201 then print("failed"); end created = true print('response.data '..response.data) results = json.decode(response.data) for k,v in pairs(results) do print(k, v) if k == "id" then stanzaID = v print ('stanzaID 1 '..stanzaID) end end end, error = function(message) print("error:", message) end }); Thanks in advance. Lorenzo
