Showing results for tags 'battery check'.
  1. Version 1.3.9
    1,459 downloads
    Over time, some useful features have been added. For example, the status of non-battery devices is also being checked. In addition,on some battery devices, the "last breached" status can be read. This for example can be useful ifa battery died between 2 wake-up cycles. So please note if the last breached status changed or not.
  2. Hi Guys, I have the following battery check script, which sends a weekly email with the status of the batteries. The problem is, only the first 980 characters arrive in the e-mail. The rest is cut off. I have tried to send a mail via the Notification Center, where I can send over 1200 characters per mail. I do not understand why it works here and not in the script. With more than 25 battery devices this is a problem. Perhaps an LUA specialist can look at this and find a work around for this problem.. Thank you. --[[ %% autostart %% properties %% globals --]] -- file: Batterystatus.lua -- version: 0.03 -- purpose: Check the batteries and email status. -- Batteries are checked once per week (Sunday on checktime) -- Copyleft 03-2017 {jwi} local sourceTrigger = fibaro:getSourceTrigger(); local oldnodeId = nil ; local subject = "Battery status"; local userId = 2 -- primary email address local checkday = 1 -- 1=Sunday 2=Monday ... local checktime = "19:15" local full = 100 --between 50 and 100 the battery status is assumed to be good local warning = 50 --between 30 and 50 battery is running low local critical = 25 --below 25 battery status is asumed as critical local empty = 255 --probably a completely empty battery Debug = function ( color, message ) fibaro:debug(string.format('<%s style="color:%s;">%s', "span", color, message, "span")) end devices = fibaro:getDevicesId({interfaces = {"battery"}, visible = true, enabled = true}) function checkBatteries() local status = ' ' ; local n = 0; Debug('withe', os.date('%c')); for id = 1, #devices do local batteryLevel = fibaro:get(devices[id], 'batteryLevel') local nodeId = fibaro:get(devices[id], 'nodeId') if batteryLevel ~= nil and nodeId ~= nil then local name = fibaro:getName(devices[id]) if oldnodeId ~= nodeId then local room = fibaro:getRoomNameByDeviceID(devices[id]) if not(room == "unassigned") then n = n+1 if tonumber(batteryLevel) >= warning and tonumber(batteryLevel) <= full then Debug('green', "Battery " ..name..' ('..room..') - Battery: '..batteryLevel..' % OK') status = status .. n .. ") " ..name..' ('..room..') ' ..batteryLevel..' % OK\n'; elseif tonumber(batteryLevel) >= critical and tonumber(batteryLevel) <= warning then Debug('yellow', "Battery " ..name..' ('..room..') - Battery: '..batteryLevel..' % Warning') status = status .. n .. ") " ..name..' ('..room..') ' ..batteryLevel..' % Warnung\n'; elseif tonumber(batteryLevel) < critical then Debug('red', "Battery " ..name..' ('..room..') - Battery: '..batteryLevel..' %') status = status .. n .. ") " ..name..' ('..room..') ' ..batteryLevel..' % Critical\n'; elseif tonumber(batteryLevel) > full or tonumber(batteryLevel) == empty then Debug('red', "Battery " ..name..' ('..room..') - Battery: '..batteryLevel..' % probably empty!') status = status .. n .. ") " ..name..' ('..room..') ' ..batteryLevel..' % Error\n'; end end end oldnodeId = nodeId end end status = status .. 'Checked on: ' .. os.date('%c') ..'\n' status = status ..n.. ' devices were checked. ' Debug('withe', os.date('%c')); Debug('withe', '------------------------------------------------------------') Debug('withe', status) fibaro:call(userId, "sendEmail", subject, status) --fibaro:call(5, "sendEmail", subject, status) local status = ' '; end -- function function main() local currentDate = os.date("*t"); local currenthour = string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) local weekday = currentDate.wday local startSource = fibaro:getSourceTrigger(); if (weekday == checkday) and currenthour == checktime then checkBatteries() end setTimeout(main, 60*1000) end if (sourceTrigger["type"] == "autostart") then main() else local currentDate = os.date("*t"); local startSource = fibaro:getSourceTrigger(); if (startSource["type"] == "other") then checkBatteries() end end
