Showing results for tags 'bbq temperature heat'.
  1. hi all, I'm looking for a setup to automate the BBQ. The temperature on my bbq can be controlled with the amount of air going in the heating system. More air means a higher temperature. Just for fun I would like to automate this, there are dedicated systems to do just that, but I have Fibaro! So what I need is a temperature measurement in the BBQ, I have some thermometers who probably work with an NTC resistance. I think I need a fibaro dimmer to measure the temperature, this is the biggest problem. How can I connect the sensor to the dimmer inputs an measure temperature? Once I've got the temperature, I think it's easy to setup a smal fan blowing into the air inlet of the bbq, depending on the wanted temperature and the actual temperature. any thought or experiences with this 'lazy-bbq' setup? cheers emiel
