Showing results for tags 'c language'.
  1. Hi there, I am facing such a problem as I can't send anything by using TCP connection from Fibaro to my Raspberry Pi using a C language's Socket Server. For more information, I am leaving my C's Socket Server as below. I can use telnet from my computer to send string to Raspberry Pi but I can't receive any string send from the Fibaro. I am using Raspberry's gpio to send Infrared code. #include <string.h> #include <stdio.h> #include <stdlib.h> #include <unistd.h> #include <sys/types.h> #include <sys/socket.h> #include <netinet/in.h> int main(int argc, char *argv[]){ int sockfd = 0,forClientSockfd = 0; sockfd = socket(AF_INET, SOCK_STREAM,0); int port = 8982; if(sockfd == -1) printf("Failed to Open Socket.\n"); struct sockaddr_in serverInfo, clientInfo; int addrlen = sizeof(clientInfo); bzero(&serverInfo, sizeof(serverInfo)); serverInfo.sin_family = PF_INET; serverInfo.sin_addr.s_addr = INADDR_ANY; serverInfo.sin_port = htons(port); printf("Starting Server at Port %d", port); bind(sockfd,(struct sockaddr *)&serverInfo,sizeof(serverInfo)); listen(sockfd,5); char sock_message[] = {"Hello\n"}; forClientSockfd = accept(sockfd,(struct sockaddr*) &clientInfo, &addrlen); send(forClientSockfd,sock_message,sizeof(sock_message),0); char inputBuffer[256] = {}; while(1){ recv(forClientSockfd,inputBuffer,sizeof(inputBuffer),0); printf("Get:%s\n",inputBuffer); } } The Client Server's Code in Fibaro HC2 as below, and I am using a button to send String. if not (started == 'YES') then started = 'YES' tcpSocket = Net.FTcpSocket("192.168.0.205",8982) end Thanks
