Showing results for tags 'command_class'.
  1. I bought a mermaid Devolo (Zipato). I get the LEDs on, but it does not sound. According to the manual there are 7 sounds and for this use this: The device supports using SWITCH_MULTILEVEL SET to play the sound The sound ID is defined as follows: 1 or 255: Emergency sound. 2: Fire alert. 3: Ambulance sound. 4: Police car sound. 5: Door chime. 6 ~ 99: Beep Beep. 0: means stop the sound. But I do not know how to activate it. Then he has some COMMAND_CLASS ....... I do not know how I can configure them with lua. Let's see if someone can help me. Thank you. ph-pse02-Zipato-Siren-User-Manual-v1-2.pdf
