Showing results for tags 'communication problem'.
  1. Hi Guys, Question, sometimes (one a month or so) it happens that the HC2 loses connectivity to the relay module controlling the heating system. This is not a good thing cause the heating system will stop when it doens't receive a command from the HC2 every 30 minutes (failsafe) So, next morning, house is cold and it takes al lot of time to heat the house again....... You can imagine this is not very comfortable and consumes a lot of electricity and gas. So, what I am looking for, is it possible to let the HC2 check communications with it's modules
  2. Hi! Since a while back now I'm having communication problems with two of my Fibaro water sensors. https://www.dropbox.com/s/0e9d3nfn2xbjly3/Skärmklipp 2017-10-31 21.41.10.png?dl=0 This is a problem since they are part of a setup to prevent my bathroom and kitchen from flooding, should there be a leak from the washing machine or dish washer. The batteries in the devices look fine in the HC2, and when i test them they do warn for a flood. But since they don't communicate with the HC2, the magnetic valve doesn't close the water flow. I've alrea
