Showing results for tags 'compare value'.
  1. hello i am trying to compare two temperatures, if tempratuurverschil is between 0 and 0,5 lower than setpointwoonkamer it needs to say is lower. But I cannot figure out how to compare the two. --[[ %% properties %% events %% globals --]] local Tempratuurverschil = fibaro:getValue(50, "value") local Setpointwoonkamer = fibaro:getGlobalValue("Setpointwoonkamer") fibaro:debug(Tempratuurverschil) fibaro:debug(Setpointwoonkamer) if fibaro:getGlobalValue('Setpointwoonkamer') == Tempratuurverschil then fibaro:debug("are equal") else fibaro:debug("are NOT equal") end if fibaro:getGlobalValue('Setpointwoonkamer') < then '0,5' Tempratuurverschil then fibaro:debug("is lower") else fibaro:debug("is not lower") end
