Showing results for tags 'delayed trigger'.
  1. I would appreciate some help with writing a scene. I've created the scene as detailed in the image below. On the press of my door bell push it triggers the scene as follows - 1) Memorise current position of CCTV camera (Memorise code placed in virtual device on button 152 press) 2) Move CCTV camera to front door preset (code placed in virtual device on button 41 press) 3) After 30 second delay move CCTV camera back to saved position preset (code placed in virtual device on button 153 press). The scene works fine apart from when the door bell button is pressed multiple times in quick succession it saves the current position (i.e. Step 1) as the front door. I need it to ignore more than a single button press until the camera has returned to the memorised position. How to I code this? Thanks in advance Steve
