Showing results for tags 'does not work'.
  1. Dear fellow HC2 users, Recently I installed the Horstmann Secure SRT323 wall thermostat, which directly regulates my potential free heating valve. If I control the temperature manually on the thermostat itself, the temperature is directly changed in Home Center. However, if I change the temperature in Home Center, it does not update the temperature. Even after one hour, the value is not changed yet. Does anyone know what goes wrong here? The other problem I have, is that in home center its status is only shown as 'heating'. This cannot be changed; not even into an OFF state. Is this normal? How am I able to regulate the temperature in different zones if the status can't simply be changed from OFF to ON and vice versa? Finally, I can't see any parameter values in the advanced settings tab either, although this could be due to the fact that Fibaro does not have its template included? Thanks all for your help!! Attached some images for illustration purposes. Best, djefmo
