Showing results for tags 'door sensors'.
  1. Please help! I am trying to use some inspiration from http://www.fibarouk.co.uk/five-things-to-do-with-your-new-home-center/to regulate my air heather pump, What I want it to do is that when any of my doors has been open for more than 45 sec, turn off the heater and then wait untill all the doors has been closed for 45 sec before turning on again. But unfortionatly i dont get it to work and cant se what the problem is. Sadly i am yet not experienced enought with lua butneed to learn, i now have 80 scenes reulating some 73 switches and sensors. --[[ %% properties 93 value %% globals --]] local Doorfront = 149 -- main door local Doorback = 50 -- Rear door local Doorside = 52 -- Side door local heater = 218 local heatDelay = 45 -- 45 seconds (the value is in seconds) local heatstart = 45 -- 45 seconds (the value is in seconds) -- Only allow one instance of the current scene to run at a time if (fibaro:countScenes() > 1) then fibaro:abort() end local value, timestamp = fibaro:get(Doorfront, 'frontvalue') local value, timestamp = fibaro:get(Doorback, 'backvalue') local value, timestamp = fibaro:get(Doorside, 'sidevalue') local value, timestamp = fibaro:get(Doorfront, 'frontvaluestart') local value, timestamp = fibaro:get(Doorback, 'backvaluestart') local value, timestamp = fibaro:get(Doorside, 'sidevaluestart') if (frontvalue == '0') and (backvalue == '0') and (sidevalue == '0')then -- is the light off? -- the doors are closed -- keep looping until the door has been open for heatDelay time while ((frontvalue ~= '0') or (rearvalue ~= '0') or (sidevalue ~= '0') or ((os.time() - timestamp) < heatDelay)) do fibaro:sleep(1000) -- let other things happen for a second, just wait here value, timestamp = fibaro:get(Doorfront, 'frontvalue') value, timestamp = fibaro:get(Doorback, 'backvalue') value, timestamp = fibaro:get(Doorside, 'sidevalue') end -- the doors has been open long enought fibaro:call(heater, 'turnOff') -- turn off the fan else -- the doors are closed while ((frontvalue = '0') and (rearvalue = '0') and (sidevalue = '0') or ((os.time() - timestamp) < heatstart)) do fibaro:sleep(1000) -- let other things happen for a second, just wait here value, timestamp = fibaro:get(Doorfront, 'frontvaluestart') value, timestamp = fibaro:get(Doorback, 'backvaluestart') value, timestamp = fibaro:get(Doorside, 'sidevaluestart') end fibaro:call(heater, 'turnOn') -- turn on the heater end
