Showing results for tags 'energy managment'.
  1. Hi all, I just joined the forum, although I'm following it from a bit of time. I would install in my home a controller for automation and would be interested in HC2, discarding other products and sw typical of DIY, even if surely much more flexible (definitely require much more time to be online). I would like to make a flexible controller to manage the energy produced by the photovoltaic, managing the individual loads so as to perform time shifting, or the separation of secondary loads. I also want to keep track of all the historical consumption, (possibly saving the recordings on an log in xml or external db sql server) of energy produced and sent into the grid. Would be nice also have a charts for lookup the state and historical data It 'a possible solution using the HC2 in combination with energy meters (eg AEON LABS 3 phase that can read the energy injected and withdrawn from/to) grid and necessary actuators? The grid supply it's 3 phase+neutral. Some load are 3 phase other 1+neutral. Kind regards.
