Showing results for tags 'energy pulse count'.
  1. hi, i am browsing several forums in order to find an answer, as i don't find any, here is my post. i have servral electrical and water devices that generate pulses on consumption. this is called S0 for instance, the electrical modules generate 1000 pulses by kwh, and the water meter generates 1 pulse by 0,25 l i would like to know if it exists a zwave counter that listen to these pulse, or if we can use the fgbs321 with lua code to listen to the pulses, but i don't know if zwave can be quick enought to react to several pulses per second. how would you do that ? thank you yves
