Showing results for tags 'extend z-wave'.
  1. Hello All I am trying to extend our Z-wave network using a HC3 Lite. Both Gateways are using the same firmware 5.150.18 Previously I tried to setup the slave but failed, found out the HC3 Master is configured with z-wave engine 3.0 and HC3L Slave was configured with engine 2.0 Updated HC3L Slave with Z-wave engine 3.0. Gateway now says compatible but lists engine 3.0 in red and slave says it needs to be on engine 2.0 I am trying to avoid a factory reset of the Master HC3 and going back to engine 2.0 (everything seems to work very well currently) for fear of not being able to load a backup taken setup with Z Wave engine 3.0 and losing devices or functionality. Has anyone had experience with this? Is there another work around setup for the HC3 Lite? Seems to be an option "Add secondary Controller" but can't find any information about this. Currently it seems the only way to use a Master and Slave gateway is to have both configured with engine 2.0 Any information greatly appreciated.
