Showing results for tags 'fgbs-001 ubs freezes halt stop temp'.
  1. I have a FGBS-001 that I have been using (or attempting to...) for 1.5 years. The unit has 3 temp probes connected, and source is a 200W switch mode power supply (which also supplies the RGBW dimmer with 40W of lights and capacity to add more RGBW's...) I am seeing the temperature flat-line from the sensor after a few hours, or days, or weeks, depending on luck. The only way to reset the temp feed is to power cycle the UBS. I can still communicate with the UBS via the HC2, changing config and the like, so it seems to be the digital controller in the UBS its freaking out seperate to the zwave controller. (this is an assumption, and I have no idea how the internals of the UBS works....) I have gone from a connection screw block from device to probes, to soldered connections (thinking dirty data from the connection block) and saw no improvement. I have done the factory resets etc.... Anyone else had these issues? Any resolutions? Any ideas? I have reached out to Fibaro email support and they proved to be consistent with my previous experience of their ability to support their products.
