Showing results for tags 'fgr 221'.
  1. Dostałem parę "starych " modułów FGR 221 ,są podobno czyste /po resecie / ,ale nie mogę ich dodać do HC lite wersja 4.15O. Czy ktoś wie jak to zrobić ?
  2. Hi! Two modules, two roller shutters with motor Alutech AM0 / 06-28, mechanical end-pieces. First I connected FGR 221, for testing. Everything worked perfectly, and in hombridge on IOS, especially I would even say in homebridge. It was a pleasure to position. Gave relatives on the iPhone access, even the switches did not put. Super. Following the order FGR 222, after installation the following problems began: 1) positioning does not work. 2) any position of the shutter is indicated as unknown position, make calibration 3) calibration does not work - If the shutter was open, then everything closes (the LED blinks red) Then it does not react to any commands anymore. - if the shutter is closed, it rises, falls and again gets stuck in the closed position. 4) part of the parameters indicated in the instruction in the configuration are missing. How to list all the parameters of the device is not known. 5) state statuses live their own lives (close the shutter in the web form of the controller, after a while the icon is "open") 6) teams from hombridge can not reach at all, or fly mines in 30-60 While dealt with 222 similar symptoms began to demonstrate 221. Up to the point that the configuration item disappeared point about positioning. Someone faced with similar? Why did the week work, and then such tricks? thank you!
