Showing results for tags 'fgt-001'.
Hi all, I'm new to HC2 having migrated from Domoticz. I've a limited knowledge of LUA and so rely heavily on copy and paste I am trying to create a scene whereby if any of my heat controllers are calling for heat a fibaro relay will switch on my boiler... and if all off... turn it off again i.e. " if A or B or C = On then set H = On elsif A and B and C = Off then set H = Off" My attempt at code is as follows --[[ %% properties 52 operatingMode 62 operatingMode 43 operatingMode 67 operatingMode 7 operatingMode 26 operatingMode %% weather %% events %% globals --]] loc
Hello, Almost two months ago @Fibaro said that a new version of FW "will be available in three weeks". As all of us can see, the "promised" time has passed. Is anybody who has any info on this? It is summer already... If we'll enter in the next winter as "testers"... I'm pretty sure we'll have no good algorithm for this winter again. On the other hand... how we can test it now? @T.Konopka?
Hi all, i recently bought a FGT-001 Thermostat and added it to my openHAB system. From what i read in the description and the manual of the FGT-001, it should be able to measure the temperature of the room. I also see a channel that is named Sensor(temperature) but it is always 0 Is my thermostat broken? Or is this functionality just not implemented and the description is wrong? Regards, Nayenia
