Showing results for tags 'fibaro dimmer 2'.
Found 3 results
  1. Hi all! I got a new house that needs full renovation. My plan is to have dimmable spots in the ceiling and to control this via a fibaro dimmer 2. Within the fibaro 2 there is a possibility for a second input. Is it possible to link a 2x2 pulse jung switch to it (e.g. https://www.elektroshop.nl/jung-pulsdrukker-4-voudig-maak.html). Have 1 of the pulse switches connected to the actual dimmer itself and have the second pulse switch connected via the zwave network to another fibaro dimmer 2. This will allow me to e.g. turn on the kitchen lights and the dining room lights form both the kitchen as well as the dining room switch. Help would be much appreciated!
  2. Andeb
    Dimming 0-10v
    Hi, I have a big problem. I have built a new house and used Z-wave and fibaro products to everything besides dimmin with 0-10v My problem is that I have a push 230v cable going to a Fibaro dimmer2, which I use to controll a Qubino 0-10v that controlls a trafo. This installation is really slow! Any idea how I can make it run faster?
  3. Witam Probuje bez skutku podlaczyc Fibaro Dimmer 2. Mieszkam w UK i do chwili obecnej w przedpokoju mam 2 wlaczniki swiatla, ktore niezaleznie od siebie wlaczaja swiatlo w przedpokoju. Po podlaczeniu Dimmera albo jeden wlacznik dziala, albo trzeba wylaczyc swiatlo tym ktorym sie wlaczylo. Wszelka pomoc jest mile widziana, zwlaszcza ze instrukcja obslugi jest dosyc uboga. Ponizej zalaczylem schemat mojego obecnego podlaczenia, ktory tak jak opisalem powyzej nie dziala tak jak powinien.
