Showing results for tags 'fibaro heat activator'.
  1. Is there somewhere a guide how to set this Fibaro Heat Activator plug-in to see reaction on Relay Switch FGS-223 that was added to the system (HC3). HC themselves are working OK, however, I do not see option to connect this plug-in to the system to further manage using switch the heating source. Regardless of temperature too low vs HC setting I can see all have [Needs Heating: NO]. Is there something I'm missing in this? Is there any guide/steps to do, to make it working as expected? I wish to add the Relay Switch FGS-223 to my (efficient but little older) heating source to swith it on/off when needed, collecting the information/status from each HC separately. However for now I feel lost. ? If this was addressed somewhere on the Forum, please redirect me. Regards,
