Showing results for tags 'fibaro motion sensors'.
  1. Does anyone experience that it is impossible to change default values for the fibaro motion sensors in HC2. What ever values I give and save is reverted back to the default values. I want for example to change parameter 80 to 0-LED inactive as I am installing the sensor in the bedroom and I for sure do not want to have constant blinking! I have also tried changing other parameters but no matter what changes I make they do not save. That is when I go back into the settings all values are back to default values.
