Showing results for tags 'fibaro relay 2'.
More search options
  1. we are in the process of remodeling our home and i am in trying to figure out if the BTICINO "sweet click" controls will work with the fibaro relay 2? I know they work as traditional toggle switches, but im not sure if they would be considered dry contacts toggle switches or not. The only info i have found is that they wont work with the Dimmer 2 modules. the only thing in their pdf, describe them as; "The electronic control which creates the perception of a digital device even in the traditional system." under the description it states: pulsante elettronico Sweet Click 1P NO - per dimmer o relè elettronici - assiale so im guessing they would work? any help with this would help me greatly! Thanks in advance Matt
