Showing results for tags 'fibaro smoke sensor'.
Found 3 results
  1. Hello I have 2 smoke sensors fgsd-002. If one detects fire/smoke i would like bots to sound siren? Is this default? Is this possible? I have a Vera z wave controller
  2. Using HCL with V4.080 Fibaro Smoke Sensor tamper not functioning. I have a scene setup in case of tamper/breach. Parameter 89 set to default value 1 - tamper alarm active, with cancellation option available Anyone else having problems or have a solution?
  3. Hi There hoping someone can assist. Using 4.057 Beta, just installed 2 x Fibaro Smoke Sensor. Shows up as a motion detector, when I change to smoke sensor it still does not work. Shows up as: (Picture attached) Version: 0.0 Configuration: Not Configured. Shows no temperature and doesnt even register as a Fibaro device. Anyone seen this and can assist? In advanced it has no parameters shown at all. Thanks Rich
