Showing results for tags 'fibaro swipe'.
  1. Last week I finally included my second Fibaro swipe and installed it on place. Inclusion went without any problems with battery supply near HC2. After inclusion I noticed that it is beeping (tree beeps) every 2 minutes or so. It was connected to same power supply Apple 10W as I have another one that works just fine. Anyway I tried with only battery supply still the same. I changed wakeup interval but still continue to beep every 2 minutes with notification that it wake up with transfer Ok. Then I remove it and include it again but now with same Apple USB power supply and still have it beeping every two minutes. I try to soft reconfigure but nothing changed. So, is there anything else that I can do something to make it stop beeping, or only solution is to exclude it and throw in trash bin?
