Showing results for tags 'fibaro universal binary sensor'.
More search options
  1. I added dallas tempsensor to my already existing binary sensor. excluded the sensor and included the sensort again. i would have expected a temperature sensor to be added next to the binary sensors. Unfortunately this did not happen. anyone have experiences like this and has a solution ?
  2. I have 3 Fibaro Universal Binary Sensors (FUBS) inside outdoor PIR's. They do their work most of the time but once in a while they "freeze" in breach mode. This is seen as the device panel in HC2 displays a "red man in motion" instead of the steady man. If a scene is based on the FUBS it will run all the time. The only way I have found to resolve the situation is to do a "soft reconfigure device" Problem 1 1a - why does a "freeze" happen? 1b-is there any other way to solve the situation? Problem 2 When I did this some days ago I found some strange things, the device was suddenly excluded from the polling que (stated in the device interface) and there was some new unassigned devices each belonging to the FUBS!! This device is displayed as a remote controller!?!? 2a - why was the device excluded from global polling que? 2b - what the heck is the new sub devices displyed as a remote controller? Running HC2 with 4.13 and the FUBS have updated firm ware.
