Showing results for tags 'flashing light'.
  1. I have had the fibaro Dimmer module installed in my kitchen controlling the lights for 4 years and it has worked just fine. Suddenly, for last 2 weeks, it has become very intermittent where when I press the switch to turn the light on, it will switch on and then turn itself off. On the app, it shows as the light is on. If I use the switch to dim, it will switch on and dim it but then switch off.. once I have done this a couple of times, it will stay on. I have got enough load on the circuit to make sure that its not load related. I also have a bypass 1 installed in the curcuit too. Any ideas why it has started doing this?? Is the module dying? I have another Fibaro dimmer which I can switch out with the current one but was just wondering the cause for this.
