Showing results for tags 'function name'.
  1. Greetings, I build a scene and I like to get the name of a variable, NOT the content of variable. Is there a way to do that on fibaro? I found some examples using _G but it is not an option on fibaro LUA framework. The reason is that I like to read 1.if variable is a function (can be done using type(v)) 2.in case is function I like to check the name and compare it with a string, so I know which function made the call. Please help! local str="test" local tbl={"one","two","three"} local fn=tostring function myfunction1() dump(myfunction1) end function myfunction2() dump(myfunction2) end function dump(v) if type(v)=="table" then fibaro:debug("Table Name : "..v) elseif type(v)=="function" then fibaro:debug("Function name : "..tostring(v)) --suppose to do compare of function name --[[ if tostring(v)=="myfunction1" then print("I was called by correct fuction") end --]] elseif type(v)=="string" then fibaro:debug("String Name : "..v) end end dump(str) myfunction2()
