Showing results for tags 'get value'.
  1. Hello I try to set value to table, but unfortunately is not work. The code is: Temp = fibaro:getGlobalValue("Sensor"); fibaro:debug(Temp); tempsen[7]= tonumber(Temp); fibaro:debug(fibaro:getValue(tempsen[7], "value")); The result is: Temp = 20 but temp[7] = nil How i can set it properly ?
