Showing results for tags 'getglobalvalue setglobal'.
  1. HC2 Beta 4.136 Getting a global var does not return a number even when it is set as a numeric. My testvalue is no string because I want to calculate it. As a workaround I compare the tostring values or force numeric evaluation with + 1. SCRIPT: -- test global var to local number comparison local testvalue = 35 fibaro:setGlobal('globalminutes',testvalue) fibaro:debug(fibaro:getGlobalValue('globalminutes')) fibaro:debug(testvalue) if fibaro:getGlobalValue('globalminutes') == testvalue then fibaro:debug("are equal") else fibaro:debug("are NOT equal") end if fibaro:getGlobalValue('globalminutes') + 1 == testvalue + 1 then fibaro:debug("are equal") else fibaro:debug("are NOT equal") end if tostring(fibaro:getGlobalValue('globalminutes')) == tostring(testvalue) then fibaro:debug("are equal") else fibaro:debug("are NOT equal") end OUTPUT: [DEBUG] 14:15:25: 35 [DEBUG] 14:15:25: 35 [DEBUG] 14:15:25: are NOT equal [DEBUG] 14:15:25: are equal [DEBUG] 14:15:25: are equal
