Showing results for tags 'global variable hue dimming'.
  1. Pfff can somebody help me..... somehow i'm stuck in my very limited lua knowledge, running version 4.049 Converting the brightness level from the hue 0-255 to the variable "Lights" to 0-100 is working What doesn't work is the using the variable to update the dim level of ID 223 Hope somebody can help me out? --[[ %% autostart %% properties 300 ui.brightness.value %% globals --]] local trigger = fibaro:getSourceTrigger() if (fibaro:countScenes()>1) then fibaro:abort(); end local Dimminglevel = fibaro:getValue(300, "ui.brightness.value") fibaro:setGlobal("Lights", Dimminglevel / 2.55) local Dimminglevel2 = fibaro:getGlobal("Lights") fibaro:call(223, "setValue", Dimminglevel2) fibaro:debug ('transfer executed')
