Showing results for tags 'hc2 will not boot af power failure'.
  1. My HC2 will not boot af power failure. When the power comes back the blue leds starts flashing but the process stops when all 8 LEDs are turned on. I have checked the bios in the HC2 is set to Power on "After power failure". The Warm Boot function (pressing the on / off switch on the rear panel) restart the HC2 and provided access to the BIOS. But the Cold Boot function (the power supply is dis- and reconnected) do not work. Only 2 times out of 10 attempts I was able to connect the BIOS settings at a Cold Boot. I also have tried to change Power on setting to "last statement" but it did not help. Then the BIOS was set back to Power on "After power failure". Since there has only been one power cut since I bought the HC2 center januar 2016, it must be open to question whether it is a manufacturing defect? Fibaro informs in a service video: "After this (setting the BIOS to: Power on "After power failure) Center should start correctly. Otherwise, it is damaged and you should return it to service". Is there someone who knows if there are more repair opportunities or whether the device should be returned to service / repair?
