I would like to ask you a question as for the compatibility of the Fibaro system with the third party product - Eurotherm Spirit Z-Wave Plus Electronic Heating Thermostat. It measures the temperature and automatically adjust the heat level. Here is the link the the product details: https://www.eurotronic.org/en/products/spirit-z-wave-plus.html
As I understood the Fibaro Heat Controller is a remotely controlled thermostatic head to control temperature in a room and it works as the actor. Which means that it can react on events. Exactly on the same principle works also the Eurotherm Spirit Z-Wave Plus Electronic Heating Thermostat. I would like to automatically set temperature in a room depending on day time (time schedule), like it is possible to configure in the Heating Panel. But when I try to configure the Heating Panel in my Figaro system, I can not find any actor there except the Fibaro Wall-Plug (there is not included any other Fibaro device of the type actor in my system). Does it mean the the Fibaro system can recognize as actors only Fibaro devices? I believed that it can work with any other device which supports ZWave protocol (ZWave Plus)
When I click on Panels -> Linked Devices -> Linked Devices - Heating -> Add -> tab. Advanced -> Main Device : as a sensor is selected the sensor build-in in the Eurotherm Spirit Z-Wave Plus Electronic Heating Thermostat (or the temperature sensor build-in in the Fibaro motion sensor in this room). Then I click the button 'Add'. Here I can not find any actor except the Fibaro Wall-Plug. As I mentioned above, this is the only Fibaro actor in the network.
I followed the same steps as mentioned in the e-learning site at http://e-learning.fibaro.com/topic/linked-devices/ but without any success. I also searched the community for the issue and checked your e-learning site at http://e-learning.fibaro.com/topic/linked-devices/ but did not find anything.
Here are my system details:
Device type: Home Center 2
Firmware version: 4.160
The main reason why I chose Fibaro was the fact that it is compatible with any device supporting ZWave. But it looks that it is only a marketing strategy and the reality is totally different.
Thank you very in advance for any suggestion how to solve this situation.
Best regards
Jan
