Showing results for tags 'heatit Controller'.
  1. At home I installed the heatit controller for my floor heating in the bathroom. Heatit unit V1.5 version - HC2 V4.090 Included in the HC2 added to my bathroom under rooms as thermostat. several temperatures are being set up in the heating panel > the whole week at 15degrees When i manually changed the temperature on my iphone app > like 26degrees (room temperature = 24degrees > then the thermostat turns on > within a minute or shorter the temperature setpoint returns to 15degrees!! When i use the website interface under heating panel "manual mode" > I can set the temperature and time manually. then it works !! What i am doing wrong?
