Showing results for tags 'home center lite inclusion the button'.
  1. Dear, I just have a new Home center Lite + a "the button "device". After inclusion of the button and the fibaro wall plug, I see the following problems: - After inclusion, the name of the device is for example 1.0 or 3.0 but never "the button" or "wall plug" - Icons aren't correct. I have icons of standard remote controller for the button for example. - I can't configure the button for the scene. When pressing on the button, I don't see anything hapenning on the device control panel. I just made a simple scene, but with the button I can't only have access to two triggers (tampered). I can't have access to single/double/... push actions. Also, when trying the scene, it works for the first time, but then, I have to awake the button to make the scene enabled again. It seems like there's no template for the device I have included. Could you help me ? Thank you
