Showing results for tags 'httpclient request curl'.
  1. Hi, I am using an httpclient request to get an address out of json array of google maps. It is working perfect but I would like to have the value out of the request scope/block. I get a value at 1 but I do not get a value at 2. I hope someone can help me. Thank you! longitude = 52.568197 latitude = 4.560753 http = net. HTTPClient () http : request ( 'https://maps.googleapis.com/maps/api/geocode/json?latlng=' .. longitude ..',' .. latitude .. '&sensor=false', { options = { method = "POST" }, success = function (result) output = json.decode(result.data); address = (output.results[1].formatted_address); print("1:" .. address) end, error = function (err) fibaro: debug ("Errortje:" .. err); end }) print ("2: " .. address)
