Showing results for tags 'humidity extractor dimmer'.
  1. Hi, I'm a bit confused about what the humidity panel is supposed to do. I have a central extraction fan that is ducted to both bathrooms and laundry room and I plan to connect it to a Qubino Flush Dimmer (since I've been told this should work, Fibaro dimmer not confirmed to work). In each of the 3 wet rooms there will be a Aeon 6-in-1 sensor to give me a humidity reading. I've so far set up one and added it to a Humidity panel. Now what? How do I use this panel for anything useful? In general I find the panels very unintuitive and the documentation isn't exactly illuminating. Best regards, Tor Magnus
