Showing results for tags 'iOs scenes'.
  1. Hi, I have created a couple of scenes which turn on one of several FGS-222 relay switches, which in turn switch on and off Rainbird sprinkler valves. So the scene is a really simple one, just turns on the Fibaro realy switch, and after some time, switches it off. That simple. When I try to run the scene from my Fibaro iPhone app (v. 2.5.2) I often have to touch the scene button several times before the scene is triggered. Especially when the phone is running on the GSM-network, and not connected to the LAN. But the most annoyning thing, is that there is no feedback whatsoever that indicates that the button was really "pusched", and worse, no feedback from HC2 which shows that the scene is actually running. So if it would be possible in some way to get feedback from the HC2 that it has received the command from the handheld and that it is exectuting the command/scene, it would be a great step forward. Thanks!
