Showing results for tags 'if else and time delays'.
  1. HI all, Very new to the Fibaro system but have already found a new favorite. I have a HC2 set up and working brilliantly thanks to the LUA support, What I am after is information on the block scenes in the HC2 Lite. Is it possible to create timers (For time delay purposes) and if else statements using the block scenes if I were to install these in customers houses. At present I can only see "and or" on "actions" and "and" in results. Does the seconds block (in red) act as a delay after that line? If these are obvious questions I apologize already. Thanks in advance Corin
