Showing results for tags 'integration with fibaro hc2'.
  1. I have bought an UradMonitor A3. (www.uradmonitor.com) This is a sensor system that provides readings of: Temperature Pressure Humidity VOC PM2.5 Formaldehyde Carbon Dioxide γ,x-rays I know some have connected it to Homeseer, but have anyone connected it to the Fibaro system? It can provide readings over wifi and via the internet. Anyone that know how this unit can be implemented into the Fibaro system? Would like the current values from the UradMonitor in HC2, so it can be used in scenes. I think this is the homeseer code: Imports System.Web.Script.Serialization Sub Main(ByVal Parm As Object) hs.WriteLog("uRad Data Retrive Started", "(uRad_data.vb script) Scripting is OK and is now running uRad_data.vb") Try Dim InputString as String InputString = hs.GetURL("IP_Address","/j",TRUE,80) Dim json As New JavaScriptSerializer Dim dataObj As jsonStructure = json.Deserialize(Of jsonStructure)(InputString) ' {"data":{ "id":"8200000C","type":"8","detector":"SI29BG","voltage":380,"cpm":17,"temperature":33.78,"humidity":33.00,"pressure":99968,"voc":244751,"co2":467,"ch2o":0.03,"pm25":1,"uptime": 181416}} hs.writelog("id", dataObj.data.id) hs.writelog("type", dataObj.data.type) hs.writelog("detector", dataObj.data.detector) hs.writelog("cpm", dataObj.data.cpm) hs.writelog("temperature", dataObj.data.temperature) hs.writelog("humidity", dataObj.data.humidity) hs.writelog("pressure", dataObj.data.pressure) hs.writelog("voc", dataObj.data.voc) hs.writelog("co2", dataObj.data.co2) hs.writelog("ch2o", dataObj.data.ch2o) hs.writelog("pm25", dataObj.data.pm25) hs.writelog("uptime", dataObj.data.uptime) hs.SetDeviceValueByRef(473, dataObj.data.cpm, True) hs.SetDeviceValueByRef(474, dataObj.data.voc, True) hs.SetDeviceValueByRef(2360, dataObj.data.pm25, True) Catch ex As Exception : hs.writelog("Urad Test Script", "Error: " & ex.Message.ToString) End Try hs.WriteLog("uRad Data Retrive Finished", "(uRad_data.vb script) Scripting is OK and has now finished uRad_data.vb") End Sub Public Class jsonStructure Public data As data End Class Public Class data Public Property id As String Public Property type As String Public Property detector As String Public Property cpm As Integer Public Property temperature As Decimal Public Property humidity As Decimal Public Property pressure As Integer Public Property voc As Integer Public Property co2 As Integer Public Property ch2o As Decimal Public Property pm25 As Integer Public Property uptime As Double End Class
