Showing results for tags 'intermittent repeating'.
  1. Hi, I have looked through the previous topics and also searched google as a whole and can't seem to see anyone else that has raised this question before. We have a number of door sensors (FGBW002 v3.2 ZW5) installed in a number of home the majority work as expected however we have noticed that a few of these sensors are misbehaving with 2 different types of problem. Periodic Repeating of event: The first issue that we have is that of periodic sending of the same event, for example we have a door sensor that will every 4m30s send an open or closed message depending upon the state of the sensor. If in between the door is opened or closed then as expected a new event will be sent with the change in state. However from then on every 4m30s an event with the new value is then sent. Intermittent Events: The second issue we have encountered is that of intermittent sending of events, in these instances we receive a flurry of events from the device the same sequence of events that one would expect to see if the battery had been removed then replaced, however no one has been near the sensor to interact with it. While not periodic, once a sensor starts to misbehave this way, we will see the more than one example of this behaviour from the sensor. As I mention at that beginning this is only a small portion of the total number of sensors that we have that behave like this. We have compared the firmware versions on the sensors reporting back to the controller and they are the same firmware versions. Has anyone else experienced similar issues to this? Or know of a fix? Thanks in advance for any insights or advice.
