Showing results for tags 'ipc-hdbw4431f-as'.
  1. Hi2UAll, If have not been able to get a Dahua IP-camera IPC-HDBW4431F-AS to work. After some investigation it seems it has something to do the way it's authenticating. HC2 JPG path: cgi-bin/snapshot.cgi (not working) - When used in a webbrowser I get a snapshot. - When using a cURL command I get a snapshot using: curl --insecure --digest -u USER:PASSWORD https://CAMIP/cgi-bin/snapshot.cgi Looks like it's using digest authentication. Is this supported by the HC2 (version 4.120)? Or this there an other way to get it working? Thanks in advance! 20170803 Confirmed: Digest authentication not supported by HC2
